Alarms & Smart Alarms
Last updated February 9, 2026
Pebble alarms are a subtle way to be reminded of an important event or that it's time to wake up without disturbing those around you.
- You can store up to 10 alarms on your Pebble.
- We offer basic and smart alarms, as detailed below.
- You can easily convert basic alarms into smart alarms and vice versa.
- Both types alert you with strong, repetitive vibration until dismissed or snoozed.
Basic Alarms
- A reliable, tactile alarm that will go off exactly as you set it.
- Can schedule which days it's enabled.
- If there isn't a symbol containing a Z beside the listed alarm, it is a basic alarm. See picture above for comparison.
- Watches from the Pebble Time collection have multiple vibration patterns available to personalize your alarm and distinguish it from other incoming notifications.
- To change your alarm vibration, go into the menu on your Pebble and select Settings > Vibrations > Alarms. Press the select button to scroll through your options and feel a sample of each.
Smart Alarms
- Pebble Health must be enabled to use the smart alarms feature.
- Will use the incoming sleep data to determine the best time to wake you, between the time you set your alarm for and a half hour before.
- Smart alarms are distinguished from basic ones in the menu by "Z" icons on the alarm listing. See image at the top of the page for comparison.
Creating an Alarm
- Select the plus symbol at the top of the alarm menu.
- Choose between "Basic Alarm" or "Smart Alarm."
- Use the up and down buttons to adjust the highlighted time (hour, minute, am/pm) and the select button to move to the next one. Note: a smart alarm may go off up to a half hour earlier than the set time, if it is a better time to wake up during your sleep cycle.
- Select whether you want the alarm to go off once or be recurring (weekdays, weekends, every day, or custom days).
- Your alarm time will appear in chronological order in the alarm menu once set.
Editing an Alarm
- To edit an existing alarm, select that entry from the alarm menu.
- You will be given the options to disable, delete, change the time, change the days, or convert between a basic and smart alarm.
- Disabling, deleting, and converting alarms are done by hitting select. To change the day or time of your alarm, hit select and then adjust the current settings using the Up, Down and Select buttons.
- You can also edit the Snooze option by selecting it and using the up and down buttons to decide your delay period (in minutes).
- Hit select to confirm when you're done.
