iOS - Common Issues & Questions
Last updated February 9, 2026
I’m not getting notifications from my iPhone!
On your iPhone, go to Settings -> Notifications, then whichever app you missed notifications from. Change the Show Previews setting from "Never" to "When Unlocked".
Still not getting notifications? Follow the steps to repair your watch here
The Bobby app isn't working with my watch.
At the moment, Bobby is not supported on iOS as we continue to work on adding websockets support to the app.
How do I use my Rebble subscription with the new Pebble app?
You don't! Voice and weather services are provided for free with the new Pebble app. Pebble + Core Devices has no affiliation with the Rebble monthly/yearly subscription.
My Pebble Classic or Pebble Steel won't appear in the Pebble app, but appears in my phone's Bluetooth settings for pairing.
The new Pebble app will only connect with watches running firmware version v3.x and above. On certain Pebble Classic and Pebble Steel watches this may pose an issue and require that you update your watch with the older/legacy Pebble app first, then install the new Pebble app and connect that way. You can follow this guide to get you set up: https://help.rebble.io/setup-ios/#1
Still having trouble? Reach out to us by submitting a bug report in the mobile app!
